S
sseahatt3
- Jan 22, 2021
- 2003
My '03 T Bird with ~90k miles has a check engine light on - see the attached photos for the codes - figured I'd post this here in case someone on here recognizes this particular combination of error messages and may have an idea of the cause.
Also to note - the engine drives fine-has normal power--but upon cold start up the engine makes a weird loud rattle/clanking sound for about 2 seconds and then it is fine. And once warmed up, its idle doesn't sound very healthy--not weak or rough but just like a heavy idle.
My guess is a timing chain guide or something like that busted and the engine has worked its way a little bit out of time. Question is how fixable is this.
