R
RichCan
- Dec 10, 2021
- 2003
Please
sign in or
join the Thunderbird
If you forgot your password
click here
It is an actuator and possibly two. Does anyone know a “shortcut” to any of the actuators short of removing the dash?Does the noise change or go away entirely when you change the air distribution from vent to floor or defrost? How about if you change from recirculate to fresh air intake. If it changes that will tell you if the actuator is causing the noise.
There are five actuators, which actuator are you trying to remove? To remove the Air Inlet Door actuator you have to remove the right hand floor duct. To remove the Floor Door actuator or the Cold Air Bypass Door actuator you have to remove the left hand floor duct. To remove the Defrost Door Actuator or the Panel Door Actuator you have to remove the plenum chamber. The Air Inlet Door, Floor Door and Cold Air Bypass Door actuators will take less then a half hour to replace. The Defrost Door or Panel Door Actuators will take over five hours to replace, because the dash will have to be removed. Now you know why I asked earlier in the thread if the noise changes or goes away entirely when you change the air distribution from vent to floor or defrost. Or if you change from recirculate to fresh air intake.It is an actuator and possibly two. Does anyone know a “shortcut” to any of the actuators short of removing the dash?
