2003 _ 2005 rear axle driver side hub assembly
Issyro
Issyro
Jul 31, 2018
Looking for a lead to obtain the rear driver side wheel hub assembly and knuckle. Need it to repair a bad one on my 03 WW.
Thank you folks, looked and it may be that I can locate a assembly here in Georgia. May have to locate a while assembly just to get may hub but i may go that path
I located 2 local junk yards and have at least eight 2000 to 2004 Lincoln LS to look at and get my hub assembly. Let u all know how it works out
Found a hub and knuckle assembly off of a 2003 Lincoln LS at the junkyard. In very good shape and I have cleaned it up and read to install it next week with better weather. 35.00 versus 761.00 brand new is a big difference!
2002-2005 Ford Thunderbird and 2000-2006 Lincoln LS both rode on the Ford frame (also shared with the 2000-2008 the Jaguar S-Type an) so look for these at a junkyard. I found one off a 2003 LS for $35.00 and it has worked perfectly on my 03 Thunderbird
The rear hub before and after I cleaned it up
