2002 Thunderbird Cooling Fan
I'm looking to get rid of the Hydraulic cooling Fan on my Bird. I'm replacing the Radiator, and would like to also be done with the current fan cooling system. Does anyone have a good suggestion for Electric replacement fan kits for this model of T-Bird? Is there any conversion temp sensor that I need to incorporate as well?
I would also be interested in a electric fan and get rid of the hydraulic cooling fan?
Gus Gutz
Well-Known Member
I know there is some sort of control device that tells the fan to spin up. The PCM tells that device to spin up the fan. I have no idea where that is but my Ford dealer replaced that two years ago when I kept overheating. I'm sure there would have to be some sort of connection to that device in your replacement
Research my posts,, i converted mine, great results
Need to remove everything pertaining to the hydrolic cooling fan, pump, reservoir, lines, expansion tank. Install a 100’’ sepentin fan belt, install a flex a lite 3400 cam 15´’ fan and shroud assembly, install a flex a lite fan speed control #31165 , and fine tune adjustments... I check my engine block temperature with OBDII reader, stays 208 degrees with a/c on, a hot day.
There are some videos on youtube where people have done this to the lincoln ls which is the same platform build as the thunderbird.
I've looked around for these videos and can't find them. Anyone have any ideas? I have the parts to do the job, just need some insight on how the radiator will come out. I'm almost there, but it seems I'm going to have to remove the A/C lines on the front radiator, and I'd rather not if at all possible.
