2002 Fuel Leak
Nov 23, 2021
Hello all, new member and I joined of course because I have a problem with my 2002 Thunder Chicken :) and was hoping to glean some wisdom from my fellow Tbird owners.
Have a pretty nasty fuel leak I just noticed under the car, passenger side about dead middle of the car. Been reading a lot and seems there are lots of different fuel leaks that can happen on this first year retro model, given the location of this leak was hoping someone would have a thought on this.
Thanks PT
Aug 9, 2005
2002s are one of a kind, But I would remove the fuel pump access plate to see if the fuel-line connections are leaking.
Does it leak all the time? or just when running?
Jun 2, 2019
Thanks PT
I would suggest taking it to a mechanism, with a lift. Knowing for sure is better than all the thoughts in China - and may keep you from going kaBoom! Also TC reference doesn’t come across as funny or respectful as I am sure that you intended. Good luck with the leak.
