P
phoeg
- Jun 10, 2018
- 2002
I have a 2002 Thunderbird, and recently the trunk lid release, driver's side window, power door lock control on driver's side do not work. The key fobs work and still open the passenger door, but you have to manually unlock the driver's door. When you lock the car using the fob you can't activate the alarm. Also, the headlights don't work, but the panel lights come on when you turn the headlight switch.
Past issue still unresolved: after a period of use the headlights would go on and off by themselves whilst the panel lights stayed on. (Drivers were mad thinking I was flashing at them.) Also...the intermittent wipers won't work. You turn to "INT" and nothing. The wipers work at high or low speed. Additionally, sometimes the wipers will come on intermittently...when the selector is in the OFF position.
So now I have all those issues. AT one point I suspected the multi-function switch had a short as the intermittent lights and phantom wiper problem appeared at the same time, but that's only theory. I thought maybe some connector in the driver's door was loose, and would explain the buttons on that door not working, but why the headlights?
Checking fuses? the manual uses all sorts of abbreviations that are then nowhere to be found, so I have no idea which ones I might check.
Any ideas based on these symptoms?
Paul
Paul
