1987 turbo coupe struts
2
Dec 13, 2022
I bought an '87 turbo coupe a few years ago as a retirement project. So now I'm retired and it's time to get started. Runs and drives. Cooling fan went out so I plan on wiring a manual switch to actuate the fan. The PRC went out recently so I want to go to a non-PRC suspension. KYB makes front and rear struts to replace OEM. Any advice on installing the struts would be greatly appreciated.
Struts are pretty easy, if you buy complete with new springs. Otherwise you have to remove and reinstall the old springs. That's kind of a pain.
Thanks. Didn't know if there was anything special about going from PRC to non-PRC outside of disconnecting the module in the trunk.
Sorry about posting on the wrong forum. Maybe a moderator will clean this up for me.
