W
wilco
- Dec 17, 2021
- 86
gas is flooding in spark plugs and oil pan. can anyone give reasons for this.thanks
Please
sign in or
join the Thunderbird
If you forgot your password
click here
If it has gas in the oil pan the seal's in the fuel pump might be bad and leaking into the pan. Spark plugs will usually get wet with gas and foul out if the car is what we call flooded. Make sure the choke is held open a bit and hold the throttle to the floor and try to start it after you dry out the plugs and use an air hose to dry out the cylinder before reinstalling the plugs. Or leave the plugs out for awhile and the cylinder will dry out by themselvesgas is flooding in spark plugs and oil pan. can anyone give reasons for this.thanks
I started thinking about that after I posted it.'86 should be fuel injected
Do a leak down check on your injectors there should be no drop in pressure when you check. Injectors get stuck open sometimes and your car problem would be one of the indications simply put a fuel pressure gauge on the fuel tap crank the car over shut the car off, it should hold pressure if the pressure goes down it’s either the fuel regulator or the injectors. After you isolate the problem, make sure you drain the oil and replace it.gas is flooding in spark plugs and oil pan. can anyone give reasons for this.thanks
