1976 bird carburetor replacement
R
Sep 2, 2019
Any input or suggestions for carbs for the 1976 460
Decided after trying to rebuild the original (three times). Went with an Edelbrock aftermarket mounted on a composite riser (to keep the heat from that big 460 down to a minimum). Never have a problem starting and runs very well now!
Also what model holley did you use and was it direct fit or did you use adapter
https://www.amazon.com/Holley-0-804...rds=0-80459SA&qid=1568043473&s=gateway&sr=8-1
I went with this carburetor and this intake
https://www.amazon.com/dp/B000CSWL0C/?tag=thunderbirdforum-20
However all the emissions on my 460 (was a late 70's engine) have been removed and capped. I would say for your 460 you would need the adapter plate for the EGR and emissions stuff unless you plan on removing the emissions.
