- Sep 9, 2021
- 1969
Hi, I recently had my new acquisition checked out by a local mechanic, the only negative he came back with was fuel leaking at the carb. It's been 35+ years since I tinkered with a carburetor. Money and skills analysis determined I was willing to replace it rather than rebuild it. I've got an Edelbrock 600CFM with Electric Choke waiting to go in (still waiting on every possible Edelbrock accessory kit to arrive before I make the swap. I've read the manual, watched all of the included videos and I'm prepared for the task, but I have a few questions.
1.) Electric Choke connection. I found a mix of years where this topic came up, some recommending the "S" wire off of the alternator, others suggesting going to the fuse panel. What current will this draw? Is the "S" wire the same as the "Stator" Terminal? Is this ok to use?
2.) Distributor vacuum port - timed or manifold port? I assume manifold as I don't believe there is emissions equipment on this car.
3.) As I said I bought all of the possible accessory sets and will return the ones I don't need. There is mention of a heat insulator gasket if the hot engine is difficult to restart after sitting for 10-30 minutes. It sounds like this may only be necessary if mounting to an Edelbrock performance intake manifold, I still have the stock manifold. What's the likelihood of needing this?
I think that's all for now.
Thanks in advance for the help.
