X
- Oct 20, 2021
- 1969
Hi All,
I hope someone can help me with this issue.
I bought this car which has been sitting for 7-8 years. Was starting and running ok . I drove it one day and when I went to start it afterwards it just does 1 click and doesn't crank.
As it is for my son I already replaced the solenoid, battery, alternator, cables, ignition switch. tune up including coil prior to this issue. I did notice that there is some type of relay next to the brake booster that is attached to a foam block on the firewall. It will click and then the solenoid clicks after. Does anyone happen top know what that relay is for? Also any ideas on what would cause a drop in electricity to the solenoid. The starter will crank if I jump it directly to the battery with a remote starter switch and bypass the cars wiring.
I'm sure it is a simple wire or connection issue but I am not savvy with electrical.
Thanks very much
Thanks very much
