BigRob89
- Jun 27, 2018
- 1966
Hello! I just bought a 1966 Thunderbird that has sat for years. I bought a new carburetor that uses a dual fuel line. The issue I have is the metal tube that runs from the front of the intake and into the back. The PCV plugs into this tube. The tube doesn’t allow enough clearance for the dual fuel line. The carb has a vacuum connection for a pcv. Is it possible to remove the metal tube and block it then plug the pcv into the carb? Please excuse my ignorance on this. I’m not even certain what the tube is called. I’ve attached a picture. The tube in question is the blue one on the left. Thanks for any help you could give.
