richardengine
- Dec 30, 2021
- 1965
Age requires a sale. No rust Arizona car VIN# 5Y83Z130448. Older restoration needs the following: Right rear window switch inop, window works with switch on left side. Power antenna inop. Sgnals don’t work, suspect problem in steering column. Evaporator return line needs replacement. AC/Heat control needs to be rebuilt. All under dash vacuum actuators and hoses have been replaced. Door locks, rear vent and trunk vacuum lines are not connected. Located in Fayetteville Ga. Asking $21,500.
