1964 window relay replacement with modern relay.
S
stevetheweave1
Oct 5, 2020
Has anyone replaced factory power window safety relay on firewall with a modern relay? If so can you share anys pictures, part numbers or wiring connections? A/C is down and window relay is very intermittant after not even a years time. Tired of rapping on relay to get windows to go down. Hot in Missouri.
You can use this kind of modern relay.
You have to replace two of the wire terminals easy to do.
Joe
