- Apr 17, 2019
- 1964
Hello all,
So, as I work on getting my car ready to go to inspection I have been working on the coolant system. It was nasty and full brown water. I took the tank off and washed it in and out. I also flushed each orifice in the engine bay about 15 minutes each. Running pretty clean now. I put a new thermostat in, added coolant and water and let it run and burp. About 8 minutes in it let out a huge burp and splashed all over the place. The water pump was hot to the touch, most of the engine was. I removed the tank and saw that thermostat looked a bit clogged. I took it out, remounted the tank, filled it with water and ran it for 20 minutes around the block, flushed it and did it a few more times. Now it has coolant back in it and a thermostat, spring part is inside the intake so hope the orientation is right.
Everything seems to flow, is there anything I should check on the cooling system? I heater core is bypassed so that takes that out of the issues. I used my thermal remote thermometer and took readings from all over the engine, 179 was the highest I saw. This is not a contact temp tool, this is the type with the laser that you point and see from a distance.
My questions are, what is normal operating temp and h9w much coolant do I need in this 390? How many gallons, quarts of the mixture?
