D
- Nov 18, 2018
- 1964
Just had the Birds Nest steering column lock kit installed but still have an issue with it popping out of Park. Not a good thing.
Linkage has been checked out. Suspecting cause is the Parking Pawl inside the transmission.
Can this be checked without removing the transmission from the car ? If that is the issue, can it be repaired without removing the transmission from the car ?
Where would you buy a new Parking Pawl ?
I have also found a TransMaxx Shift Improvement Kit. It’s for a C3 but not sure it’s for the 64.
Any suggestions/info is appreciated.
