1964 recommended improvements | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter Alex’s64
Alex’s64
Alex’s64
My son just bought a 1964 Thunderbird for his first car. He is only 14 so we have a little time but we are building a 1965 Ranger right now as well. The Thunderbird will be his daily driver so I want it to be safe as we can get it.
We are installing 3 point seatbelts first thing. I am thinking of doing a disc brake conversion and a passenger side mirror as well.
What have been some of the best modifications have you completed or seen?
Thank you
Thank you
Electronic ignition, Pertronix and a higher output coil. Heavy duty sway bar at the front.
The first improvement you can make to any 1960's daily driver for a new driver is another car with modern safety features. Old cars are incredibly dangerous in serious crashes, even the steering wheel can kill you. There is a misconception that old cars are "built like a tank", however they do not absorb the energy of the crash. Installing a 3-point safety belt is not going to help you in an offset head on collision as seen below.
Thank you for the suggestion. You are right biddle. He will be driving his car to and from school and work only! 25 mph unless the family is out for cruise night then high speeds of 35. We all have classic cars. My wife drives her new 4Runner which will end up as my sons as well.
Thank you
I've had my '64 since 2018 and have raised four teenagers, and here's what I would recommend:
Go through the brake system completely and make sure hoses, lines and components are up to snuff and not worn or leaking. Yes disc brakes would be a nice to have and a fun project to install, but drum brakes are fine for now if you want to prioritize the disc brake conversion to later. Best to install a dual master cylinder in either case for safety reasons. Keep an eye on brake fluid level in the MC to detect any leaks, including the insidious leak from the MC into the booster. Make sure the e brake is properly adjusted and the vacuum release mechanism is working properly. And make sure the vacuum line to the booster is in good condition/no leaks.
The shift mechanism is a weak point on these cars. When the shift lever, detente plate or steering column bushings are worn, the shifting isn't positive. The transmission can hop out of gear unexpectedly, and Park may not hold. Make any repairs necessary. Check the swing away steering mechanism operation to ensure that when the steering wheel is swung all the way to the right, the car is locked in Park. He should do this whenever he parks the car on a slope.
Make sure the gas tank and associated hard and soft lines are in good condition and there are no leaks.
Make sure the power steering system is operating properly and the hoses are in good condition and not leaking. The steering wheel should be very easy to turn when the engine is running. And if the power steering should fail while driving down the road, the car would be very difficult to control.
Make sure the suspension is tight. If the control arm bushings, ball joints or other suspension components are worn, the car will wander and be difficult to control, especially at freeway speed.
The '64 didn't have rear seat belts standard, so installing belts in the rear is important.
Also, make sure your son understands that it's not a muscle car. It's 4400 pounds of iron that can do a lot of damage, and it must be driven responsibly and conservatively for the safety of passengers, other drivers and pedestrians.
Should be a fun project for you guys, keep us posted!
Doug
Do what the other guys recommend. AND, check the gas filler tube (runs from gas cap thru the trunk to the tank). If this has any leaks, a serious fire can occur
I just recently bought a 65 and noticed that exact problem with the gas filler tube. Have been working on other things and I need to add that to list.
Previous owner replaced the gas tank.
What’s the best way to fix this?
First, check to see if the tube is rusted thru. (Remove trunk lining/carpet/cardboard and visually check it). Look down the tube with lights……
Or, next fill-up, open the trunk and check for leaks while gas is flowing.
If no internal leaks, the rubber seal at the tank is leaking. You can buy them, but it’s not the easiest thing to replace. (It’s under the car).
Good luck.
