1963 brake line hose size
H
Dec 6, 2022
I noticed that my brake lines coming out of the master cylinder start as a 3/16” line and about a foot from the rubber line at the front wheel cylinder it goes to a 1/4” line at the fitting. Is this normal? Appears to be factory. 3/16” line appears to be brazed inside of 1/4” line. I want to replace the lines without buying factory bent lines, don’t see a problem with 3/16” lines all the way. Thoughts?
