I have a recently imported 1962 Thunderbird hardtop with a US conversion. It now runs 15 inch hubs over front discs Please refer to attached photo Can anyone help me identify the conversion? The hubs are about 5mm larger than the rear drum originals
Hi Dave. This is off topic but I really like this pic of your car from the Photo section of the forum. As much as any TBird pic I've seen, these embodies what gets our juices flowing. I'm just curious what it's like owning one of these cars in Oz. It must be really unusual to see them on the road down there.
Nothing constructive to offer on your disc brake question I'm afraid.
Not really sure of the conversion source. It is likely a GM caliper. I cannot see the rotor with the wheel spacers over them. I am not quite sure what you mean by 15" hubs. I would point out that if you now have 15" wheels you should not need the wheel spacers. If you are still using 14" wheels then that is the reason for the spacers. The original wheels did not have a rim that was designed for disc brakes. The spacer moves the rim out to accommodate the original wheels. You might be able to use a more modern 14" wheel that was for a disc brake wheel.
good luck, J.
