johnpaul
- Mar 15, 2019
- 1962
I replaced the spark plugs and coil and did something wrong with one of those replacements. Unfortunately, I didn't try to start it between replacing the spark plugs and replacing the coil, so I'm not sure where I went wrong. I gapped the plugs, connected each spark plug wire to the correct cylinder, and I rewired the new coil just as the old one was. It was a cold start after sitting for a week so I expected some cranking, which it did. Sounded like it was going to turn over, then when I attempted again it cranked briefly and then stopped cranking altogether even though I still had the key in the start position. This occurred after several more attempts to start it, even after switching back to the old coil. The last attempt resulted in that awful grinding starter sound, which is when I quit. Any thoughts? It has pertronix electronic ignition, which was working fine prior to all of this.
