madcap
- Oct 31, 2022
- 1962
First thanks for the site. I’ve found a lot of great info on here. I’ve built quite a few cars over the years and consider myself quite mechanical. That being said I’m an idiot that I can’t figure this out. I had never seen the original “pull” style starter before. It was giving me issues hitting the flywheel and making an awful noise. I ordered the new starter drive from Total Performance and installed it on a big block starter as instructed. The started tested fine on the bench. I installed it and it fired right up. Took it for a test drive and it re-engaged. I shut it off then tried to start it. It “smoke tested” along with negative battery cable.
I little back story. I found this car in a garage after sitting for years after a “restore”. It wouldn’t charge, I took the generator and voltage regulator to a shop that’s been doing these things for years. The generator was fine, but the voltage regulator was toast. I replaced the regulator and horn regulator just to be safe.
Do I normally need to shim the newer style starter? Do I need to ground it differently? Could polarization be an issue? The negative cable is currently attached to the block. (It’s a clean connection)
Could it be the ignition switch? I have the body and electrical manuals that everyone recommended. Just doesn’t make sense to me.
Thanks in advance
Thanks in advance
