1961 Convertible pump/motor replacement
Mcmazzio
Jan 11, 2021
Has anyone changed the motor/pump to a high capacity unit? It looks straight forward but curious if there are pointers of what to do/not do from someone who has done it. Also, I have heard you shouldnt mix trans fluid with brake fluid. How do I determine what is already in there?
Thanks
Thanks
I haven’t changed my pump but I can say that replacing 55 year old brushes is like getting a new pump. Worth the trouble.
You can generally tell what fluid is in there by color. ATF is red, brake fluid is typically clear but for the new exotic types which probably aren’t in there, anyway. I know by ‘66 it was supposed to use ATF, I don’t know what was specified for ‘61. If you change from one type to another I’ve been told you should flush it with alcohol first.
