D
dnoldy
- Nov 22, 2020
- 1960
Hi all. Have a 1960 t bird. Put the rear window down and now won’t go back up. Switch bad? Or something else? Thanks in advance
Please
sign in or
join the Thunderbird
If you forgot your password
click here
I had similar problem on my 62. Do both the drivers door rear switch and the switch by the rear window not work up & down.Hi all. Have a 1960 t bird. Put the rear window down and now won’t go back up. Switch bad? Or something else? Thanks in advance
I’ll have to see, didn’t try the others. What was the problem with yours Rob?I had similar problem on my 62. Do both the drivers door rear switch and the switch by the rear window not work up & down.
With mine, all windows went UP & DOWN from the driver controls. but right passenger would go down but not up from the passenger door switch. Turned out to be a single broken wire near the door hinge.I’ll have to see, didn’t try the others. What was the problem with yours Rob?
