1957 ignition switch correct wiring
valhalla 4771
valhalla 4771
Apr 29, 2017
Trying to re-wire everything. Discovered my ignition switch doesn't match up with my full color-easy-to-read ClassicCarWiring diagram. The diagram shows 4 terminals S, AM, C, and AC. My switch (see photo) shows BAT, ACC, ST, and IGN. Do I have the correct switch? If not, I'll order one. In the meantime, can someone match up the two labels for me?20070101_01_20.JPG
When you post to the forums, your subject should summarize what your post is about. "1957 ignition switch" could be anything, selling one, buying one etc. I will revise it.
Batt = AM
ACC= AC
IGN = C
ST = S
Looks like an aftermarket part
from the back side it looks like an original
if it fits into the dash properly
It should work
Ignition Switch Wiring
On the Batt or B terminal – Yellow wire from the B terminal of the headlight switch
On the Start or ST terminal – Red/blue wire going to the starter solenoid
On the Ignition or C terminal – Red/green wire going to the Batt terminal of the ignition coil
Black/green wire going to the charge indicator lamp
Black/green wire going to the oil pressure indicator lamp
On the Acc or A terminal – Black/green wire going to fuel gauge
Orange/yellow wire going to the fuse for the turn signal flasher
Brown wire going to the fuse for the blower switch
Black wire going to the fuse for the radio
Red wire going to the circuit breaker for the power seat switch
Black wire going to the fuse for the overdrive relay (if equipped)
Red wire going to the circuit breaker for the power windows
