- Feb 14, 2014
- 1957
Does this line mount on the bracket above or below the clips' fastener? Assume it's on the fender side of the bracket
Please
sign in or
join the Thunderbird
If you forgot your password
click here
I realize the larger loop goes on the fuel line but don't know if it came from the factory above or below the fastener.You will notice that there is a larger loop on the hold down bracket. That is for the fuel line itself. On mine the line goes under the hold down screw. It will work either way depending on how your fuel line naturally rests.
Mine is below. pretty sure that's the way it was built.I realize the larger loop goes on the fuel line but don't know if it came from the factory above or below the fastener.
If it is really important to you to be exactly correct I suggest you purchase the concours restoration manual. Unless you are entering judged show it will make no difference. If you are entering judged show you will need the restoration manual.Does this line mount on the bracket above or below the clips' fastener? Assume it's on the fender side of the bracket
It's not important enough for the couple of questions to buy a complete set of judging standards as I am not entering national judging. Since I prefer to be correct where possible on all of my cars, it's why I refer to those who may know for the few areas I'm asking about. BTW, I got my answer: thanks Ward 57.If it is really important to you to be exactly correct I suggest you purchase the concours restoration manual. Unless you are entering judged show it will make no difference. If you are entering judged show you will need the restoration manual.
