1956 Tbird fuse holder location
A
Sep 11, 2020
I have a 1956 Tbird and was under the dash doing some repairs and was looking for the fuse box and could not find one? Is it located some other place or is there not one? Thanks for you input...Jerry
My '57 has multiple single fuse holders throughout wiring system, also the rear of the headlight switch has a standard fuse as well as a internal resettable fuse.
The '55-'57 birds so not have a fuse box per se... they only have inline glass fuses for the radio and other electrical devices.
OK good that is all I could see. Thanks for confirmation. Jerry
If your not sure which fuses go where? The following should help:
Clock - AGA 1
Radio - SFE 7.5
Map Light - SFE 7.5
Heater Motor - SFE 14
Turn Signals - SFE 7.5
Overdrive - AGC15
