You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
1956 Speedometer fitting ratio?
Thread starter
odlewis
Start date
The cable is turned in reverse, and from what I marked on my angle drive, the speedometer gear (now made of plastic) does turn my cable very close to 1:1. I have seen different speedometer gears sold at the Thunderbird houses offer different teeth count. Mine has 19 teeth.
