A
albjerryg
- Sep 11, 2020
- 1956
Please
sign in or
join the Thunderbird
If you forgot your password
click here
Mine is about 17" in diameter. Yes that is stock. The old wheels were large so you could have good leverage at slow speeds as may cars were built without power steering. Aftermarket wheels that are smaller are available so larger people can fit behind them. The cockpits are small as people on average were smaller in the 50s. I'm only 5'6" 130lbs and I have the seat all the way back and the wheel all the way forward. It helps being small when I need to crawl underneath the dash.OK thanks for the good advice and I have a shop manual on order it has not arrived yet. The reason why I asked if it was standard because it is so large about 18" ROUND? Thanks again Jerry
I wanted to know if the steering wheel in the picture is the correct one for the 1956 and also I want a tip on how to remove it? Thanks for any help...JerryView attachment 13596
it sure looks like the original,to remove horn ring ,push it in and turn to the left,after removing ring you can remove nut and then use a puller to remove steering wheel.I wanted to know if the steering wheel in the picture is the correct one for the 1956 and also I want a tip on how to remove it? Thanks for any help...JerryView attachment 13596
No a 1956 wouldn’t have Rack & Pinion originally, if your looking for more room between the seat and the steering wheel they make a smaller replica wheelYes I am not 135lbs and the seat won't adjust so I am in the process of taking it out and seeing what wrong with it. Also there is no problem steering this car has rack and pinon steering. It looks pretty old I did not think they made it in 1956. Thanks Jerry
I agree the size of the steering is enormousOK thanks for the good advice and I have a shop manual on order it has not arrived yet. The reason why I asked if it was standard because it is so large about 18" ROUND? Thanks again Jerry
