- · Viewing forum 1955 - 1966 Classic Ford Thunderbird
- Mar 17, 2020
- 1956
Hi, I was wondering what range of gas and oil mileage you guys get. I have a 56 bird auto with 312 engine. I added the PVC system to my car to eliminate the oil drops from the road draft tube. Because the standard set up for the 312 doesn't have a very good oil air separator I'm thinking that I might be pulling a little more oil into the intake using a system with higher vacuum than would ever have existed with only the road draft tube. I've been driving the car on the freeway at 70 mph (3000 rpm) quite a bit lately and I think I'm getting about 750 miles/qt oil. At those same speeds my mileage is around 12 mpg. I did rebuild the engine and used cast rings to get it to break in quickly and figured I never would put on enough miles to wear them out. I didn't run the car much before I added the PCV to have any idea about the oil mileage stock.
