1955 starter runs when ignition is off
Dick Rupp
Dick Rupp
Aug 17, 2017
Starter sometimes continues running even when I turn the ignition switch off. I have to disconnect the battery to stop it.
Updated title from 1955 Tbird starter to 1955 starter runs when ignition is off. Good titles get more responses.
sounds like your starter solenoid is sticking,
they are relatively inexpensive. may want to replace it.
I carry a spare in the trunk.
they are notorious for failing. usually it is a no start
The cause the starter continuously running could be either the starter solenoid or the ignition switch. The next time it happens, I would remove the red wire with the blue band from the starter solenoid. If the starter stops running than the ignition switch is the cause, but if the starter continues to run with the red wire with the blue band removed from the solenoid, then the solenoid is the cause.
could be the solenoid stuck like was said, or the bendix spring is broken and starter stays engaged with the flywheel gear. either way, spinning the starter at 6,000 RPM because of being engaged to the ring gear, you may want to replace the starter also.
