1955 Rear end sagging | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter Tom Bloesch
T
Tom Bloesch
2
I think the left rear leaf spring on my 1955 has lost its spring. The left side measures 24 3/8" from ground to center of tail light, the right side is 25 5/8". The first four pics are of the left side and the last four are of the right side. What do you all think?IMG_7307.JPEGIMG_7309.JPEGIMG_7311.JPEGIMG_7313.JPEGIMG_7308.JPEGIMG_7310.JPEGIMG_7312.JPEGIMG_7314.JPEG
I don't have the unevenness you are experiencing but I want to firm up the ride, raise the back end by 1" and I'm replacing the entire suspension. I have been working with Eaton Detroit Springs to replace the springs and shocks. They are very knowledgeable and friendly. They aren't cheap but I'm confident I'll get what I need exactly!
This observation may have nothing to do with your ride height problem, but did you notice the difference between left and right side bottom shock rubber bushings? The right side bottom rubber is not compressed at all compared to the left side bushings and it’s above partner.
Good eye, I’ll have to check that out. My father in law gave the car to my wife and I, he was in the process of restoring it and realized that he was no longer capable of doing the work.
Birdman of Coatesville 1955 weighs in about 2800 to 3200 lbs springs rated at 750 lbs per side the gas tank sits more to drivers side and the weight of driver could cause spring to weaken more on that side. I would take it to spring shop before replacing they can re arch springs and replace what’s needed
I'm not an expert, but you have plenty of room on the U-bolts... what about a shim?
On our 57 we had a similar problem, I had a local company reset the original springs up 25 mm and added an extra leaf. Problem solved. They had the correct height settings and calculated the height needed and just added 25 mm. I also fitted KYB gas adjust shock absorbers. We still have a really nice ride without issues.
I agree with having the springs rearched . What you don't want is a new or "heavy duty" spring that will lift the rear of the car to high. Stance is everything.
Totally agree, our car still sits at the correct height but the extra leaf and shock absorbers have improved the overall handling, 20250909_152812 Copy.jpeg
