T
Thunderbird Ed
- May 5, 2021
- 1955
Please
sign in or
join the Thunderbird
If you forgot your password
click here
I would love to hear or see the difference in these imported parts.There is a current problem with replacement fuel pumps. I am not close enough to my reference right now to be more specific. The ones made in Mexico seem to be better than the ones from China. One has screws and the other doesn't. Hopefully another member of our merry band will have the quick answer as to how to identify which is which. I hope I have not muddied the waters in my attempt to provide a bit of clarity.
If you have the original pump with the hex bolts it's an easy rebuild. Kits from auto parts stores should be readily available. The re-pop's do not have the screws around the top and cannot be rebuilt.To my knowledge the good ones have hex head fasteners holding the pump body together whereas the bad ones (more prone to problems) have Phillips head screws.
the good one I got I believe came from “Macs T Bird “
I’m sure if you called any of the many good vendors they would be happy to take on out of the box and check for you.
Pull the pump and have it rebuilt. It's almost impossible to find anything new that works. Just put up with the wait and find another project to work on in the meantime. I had mine rebuilt for that reason plus all the new materials can handle methanol and it works better than it has in years. Also it's worth the money to have it done right. Trust me. There is a reason the core charge is high, it's worth it, the originals are becoming hard to find as too many shade tree mechanics throw out the original for a replacement before they confirm the replacement actually works. I found a rebuild kit and had a local shop that specializes in '50s & '60's Fords to rebuild it. Still took a couple of weeks.After installing a new high output water pump and volute spacer I took my car for a test drive and discovered a seeping fuel pump. Checked with a couple of parts suppliers and learned I have a 4-6 week wait. I did find a couple of Carter fuel pumps. Does anyone know if they are US made still or did they go over to the "dark side" I have no desire to go electric. I try to drive the Bird at least 4-5 days a week .
I found a kit but my rebuilder said he had to remove and then attach the diaphragms to the actuators and rebuild it from scratch. I think there is a kit supplier 'Then and Now' that found a supplier that already has the diaphragms attached to the actuators. It's been a year so I may be a little foggy. Good move the originals are becoming invaluable and work great as designed.I am already on the list for a rebuild. I would do it myself, but I can't find a kit.
CASCO is showing two different rebuilt pumps that they sell. Do the demand; you will have to check to see if they have still have any in stock.After installing a new high output water pump and volute spacer I took my car for a test drive and discovered a seeping fuel pump. Checked with a couple of parts suppliers and learned I have a 4-6 week wait. I did find a couple of Carter fuel pumps. Does anyone know if they are US made still or did they go over to the "dark side" I have no desire to go electric. I try to drive the Bird at least 4-5 days a week .
