- Mar 2, 2020
- 1955
Question: How does the economizer diagram operate? Does vacuum pull the diaphragm up compressing the springed plunger causing the power valve to close and when vacuum drops (WOT) does the spring force the plunger to push the power valve open allowing more fuel?
If so, with the engine off and no vacuum holding the plunger up, would the power valve be open draining the fuel bowl into the intake?
Is the power valve routed into the tubes on the backside of the float bowl? Don’t have the diagram handy.
