Where's headlight beam adjustment?
W
Jun 26, 2005
Where is the headlight beam adjustment screw on a 2002 Tbird?
I didn't think there was one... Seems like they are a bulb that inserts into a fixed housing. Did you look under the hood at the top bolt holding the headlight assembly in? On a large number of 2002s the plastic mounting boss that the bolt goes into cracks or breaks all the through. Could yours have broken all the way and the headlight housing is loose? If you need a replacement headlight get a 2003 or later as that attach point was redesigned after 2002.
