C
Chzyrider
- Mar 7, 2010
I am trying to install an oil pump rebuild kit that came with the new pressure relief valve/spring and cap on a '92 w/ 3.8L engine. The cap appears to be pressed into the timing cover to retain the valve and spring in place. It's like a freeze plug into the block, but turned over so the smooth side is facing up. IS THERE A TRICK TO REMOVING THE OLD ONE? It looks like I have to totally destroy it to remove it but I don't want to damage the hole in prying on it to get it to pop out.
