You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
Hazards not working on '97 Tbird
Thread starter
Luckyontheducky
Start date
I brought it used and I found a lot of dashboard lights that would stay on after starting it.
The reason was that the ignition was turned to far forward.
I positioned the key by turning it backward toward me and all of a sudden the lights went off.
Also I had to replace the starter prior to having the ignition turned to far forward, which cost me almost 200.00.
Give it a try, positioning your ignition.
sincerely, Larry Duncan
