Z
Zenriddle
- Sep 12, 2013
- 1997
These 1997 4.6 T birds come out of the box with an electric fan some posters install a switch under the dash when the temp sending unit or relay fail What if I use a flex fan or clutch fan on the water pump and still have the electric fan on a relay that only comes on with the ac or when the key is switched on the fan shroud is off a little bit but I can do it and it will come out perfectly fine has any one ever a temped this and did they
post the results
post the results
