Huth383
- Apr 6, 2017
The ABS light is on and stays on it is a 2002. From the research I've done everything points to a bad clock spring in the steering column. Does anyone have info on this repair??
Please
sign in or
join the Thunderbird
If you forgot your password
click here
I had my ABS light on for a couple of years before I finally took it in to have it fixed. The good news was that it was the clock spring. The bad news was that it thru another code after replacing it. The new code eventually pointed to replacing the passenger side airbag. I also had brought the car in at the same time for the air conditioner not working which turned out to be a bad compressor. Needless to say, it was over two weeks in the shop and almost $3400.
I have purchased the clock spring and will make the repair soon. Everything else is in great shape right now!!I had my ABS light on for a couple of years before I finally took it in to have it fixed. The good news was that it was the clock spring. The bad news was that it thru another code after replacing it. The new code eventually pointed to replacing the passenger side airbag. I also had brought the car in at the same time for the air conditioner not working which turned out to be a bad compressor. Needless to say, it was over two weeks in the shop and almost $3400.
The only special tool you need is a steering wheel puller. The part is plug and play. Not much to it
