I'd have some interior pictures, but the past 4 year or so have not been kind. My rear window has been leaking and causing my rear seats to get wet, then dry excessively and are now starting to split at the seams. The front side bolsters on the driver's seat are also getting very worn as well. I'm actually planning on doing a complete interior swap at some point in the future. I'm currently debating on going with a '94-'97 swap or going with something a little different and installing a Lincoln Mark 8 interior. Either way presents a little difficulty as the emergency brake on the SC was on the center console, not on the floorboard as in all other models of the T-bird. And who knows, maybe I'll just stick with what I have. I've got some other projects that I'm beginning to seriously consider. And as such, may end up finding a stopping point on the SC sooner rather than later. But for now, I've got a lot of engine/performance upgrades coming soon. I will be getting a fresh shortblock and also install a high stall non-locking converter. The shortblock has a cam in it, albeit a small cam, but still much better than stock. I've got a set of underdrive pullies coming to me as well. Then I'll begin earnest work on my performance heads. I've got a set of ported heads, but these will be with aftermarket (larger diameter) valves, springs capable of providing the lift the cam will be making. Money permitting I will also be building a custom intercooler that is quite a bit different from anything anyone has done so far. I'm also stepping up to a better inlet plenum as well as a slightly larger throttle body. A few other mods that are less performance oriented may find their way into the car as well, like a battery relocation kit and a deep transmission pan. I've also got a set of HID conversion lights for the high beam, with the low beam already purchased, but on back order.
And when I replace the engine, I will be cleaning up my engine compartment significantly. I will steam clean the compartment and repaint the entire engine bay.
That's the plans I have for this year, plus some of my maintenance, like getting the rear window resealed and my rear differential rebuilt. I've got a pretty ambitious goal this year and I'm already on my way to having the
parts. When it's all said and done, it will be much nicer than it is currently. But that's assuming I end up having the time to complete all this as well! LOL!
