1992 302, Think front cats are plug
R
Aug 13, 2017
o2 sensor is behind cats,
Has anybody hollow cats out ?
will it toss out a code with cats hollow out and 02 sensor installed?
nowt worry about insp.
No, but if u hollow out the cats it could cause hp issues, not sure about the 5.0 but some motors need back pressure to work properly
Had a 92 sc with no cats, I used the o2 adapter to pull the sensor out of the stream and back a bit further, never threw a code
