1980 wiring diagram
R
Aug 11, 2023
Hello all, Working on a 1980 bird with a power window problem. I need a wiring diagram of the wiring that shows the wiring from the
source . Ignition switch ? to the breaker . Also , I can't get the fuse block out easy. Do you need to remove dash panel? Thanks RJ
