You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
1965 - Question on tires
Thread starter
Hank Chinaski
Start date
You can check Coker tire but you will fine that the prices are extremely high. If you can deal with just white walls and brand can supply you with a good tire. Good luck Rick
