M
mikesizzle
- Aug 3, 2011
- 1964
I found a frayed wire wrapped around the steering column by the flex coupling (rag joint), about a foot long, no insulation but it has a two by 1/4" flat hard plastic piece attached. I also see a broken wire below the brake booster in the same general area that may have been spliced in by a previous owner. Everything seems to work. If there is a column ground wire, where is it?
