1963 transmission fluid type | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter Dustin F
This is probably one of the worst questions to answer because there is SO much information. Let me tell you what an oils engineer told me about this year ago. I am sure your manual says to use Type A, Suffix A. This was a fluid actually made with wale oil. It was phased out and the actual replacement for Type A, Suffix A is Dexron, or now Dexron II. This is the closest oil to the original. Type F does NOT stand for FORD, it is a fluid used in the late 1960's and early 70's Ford vehicles but type F was like Type A, it did not stand for a particular model or make of car. It had what are called friction modifies that caused the clutches to grab instead of the slight slip.
I am sure you are going to get a ton of people that say Type F is for Ford. Lots of people have and are using Type F and it appears to work. If all you care about is something that works, either Dexron or Type F will work. There are lots of stories about people using Type F with no adverse effects. If you want to use the fluid that is closest to the original, then Dexron is what to use. If you like the sound of Type F because it sounds like something a Ford should use, then you can use that and it will work also.
Type F and Type FA are available. It's not rocket science.....
We are to use type F fluid in our older Thunderbirds. Proof from the Phillips66lubricants.com website:
Phillips 66® Type F ATF is specifically designed for use in automatic transmissions in passenger cars and light trucks manufactured by Ford Motor Company prior to 1977, and in many 1977-1981 models. It also is recommended for use in many Borg-Warner automatic transmissions and older Ford power steering units, as well as in the hydrostatic drive systems and hydraulic systems on certain farm equipment.
Phillips 66® Type F ATF is specifically designed for use in automatic transmissions in passenger cars and light trucks manufactured by Ford Motor Company prior to 1977, and in many 1977-1981 models. It also is recommended for use in many Borg-Warner automatic transmissions and older Ford power steering units, as well as in the hydrostatic drive systems and hydraulic systems on certain farm equipment.​
