1957 alternative 4 speed transmission
twstnshout
twstnshout
Nov 19, 2021
After almost 2 years of body off restoration on my 57 3 speed overdrive, I’ve been driving it for several weeks. I’ve done the same process to 3 early vettes over the last 12 years and frankly this 3 speed overdrive sucks. Cant downshift to first unless you come to complete stop and I do mean complete! And really downshifts to second are almost as useless. The motor winds up way to fast because of the rear end gearing with the 3 speeds even with the cumbersome complicated overdrive system . I would love to install a 4 speed. Would an early too mid 60s ford 4 speed fit the tbird bell housing and available room in the transmission tunnel? Would a drive shaft have to be reconfigured? Would a 4 speed off a 289 out of a mustang work? There must be thousands of them around. This can’t be an unusual issue. But I do love the original shifter and knob.
There are some ways to convert to a 4 spd... wish I was familiar with what they are but I've been told none of them are a direct bolt-in project. Modifications are needed, including the driveshaft.
The top / 4th gear in an 'older' 4 spd is a 1:1 gear ratio, same as the 3 spds without OD. I had a '71 Merc that came with a 3 spd stickshift, changed it to a 4 spd and just spent more time shifting gears, felt like I was rowing the car down the road.
You'll lose OD and still have the same lower 3.70 axle gear ratio that came with the OD transmission unless you change the axle gears too.
Some of the late 70's and newer manual 4 or 5 spd transmissions have a built-in overdrive top gear but may(?) not fit as easily as an older version, and you may still want to change the rear axle gears.
Hopefully I don't have a similar problem. There's a project '57 Bird in my garage, also with a 3 spd OD transmission. The OD section of the trans was blown and replacement parts for it were unavailable during all the covid shutdowns. Almost had to buy a newer 5 spd & adapters just to have something to put back in the car, but VanPelt Sales found some dusty NOS parts for it.
Maybe you might try using a rear end for a 57 automatic. Automatic rear end I think is around 3:55 axle gears ratio. You could also have the transmission rebuilt and have full Synkro gears put in.
Maybe you might try using a rear end for a 57 automatic. ...
Here are the usual rear axle ratios for '57 Birds
Code / Transmission .................. Rear Axle Ratio
1 ... manual 3 speed ................... 3.56:1
2 ... manual 3 speed w/ OD ..... 3.70:1
3 ... Fordomatic ............................ 3.10:1
Downshifting:
1. shift into first' easily done when matching the engine rpm to the transmission need for rotational speed. Yes 1st gear is not synchronized. it is a skill that is relatively easy to learn.
2. shift down to second; what do you mean by useless?
3. A change of transmission will almost always require a driveshaft of a different length.
4. I have used a T-85 overdrive for many miles without problems. Some trips have been well over 2000 miles in duration. Despite the manner of the mounting the shifter, it has been easy to shift up and down. Any mechanical device will only operate as it was designed to do. It will not bend to your uses just because you find dislike how it operates.
I would think that you realize that while in overdrive the transmission will freewheel when not accelerating and have no "engine braking".
When in overdrive the procedure of momentarily backing off the throttle above ~27 mph you will shift into overdrive.
Changing to a mustang 4-speed will give you the same final drive rpm as a non-overdrive 3-speed or the O.D. when not selected into overdrive.
The input shafts should be the same length, but you will want a narrow pattern case to bolt to your bell housing. If you do not have a narrow pattern you may be able to drill your bell housing in a wide pattern. That part I am not sure about is drilling the bell housing. You will need to compare the transmission face of the wide pattern to see if there is sufficient surface to re-drill for a wide pattern.
You will need an after market shift mechanism and remove the original shifter. One complaint I have with the original shfter is it is mountde to the floor-pan of the body and not directly to the transmission. As the engine torques over under acceleration the the shifter does not go with it.
If you use an aluminum case to loader from say a 1980 ford pickup or Fairmont it is essentially a three speed with fourth being overdrive. The caveat with the the aluminum case is the shifter position. Depending on the original installation the shifter will be either forward located or rearward located.
A 5-speed T-5 transmission can be mounted. It would require an adapter between bell housing and transmission. You will need a different clutch disc to match the spline of the T-5 input shaft. The shifter may require an aftermarket or modified shifter to locate the shifter in an easy to use fore and aft location. Additionally the shifter will not likely "fall to hand" and require a modification to the transmission tunnel. Finally a new or modified carper may be needed for aesthetic reasons.
Downshifting:
Basically make sure your transmission is working to spec. and learn how to drive it. Ever tried learning how to drive a tractor or skid steer loader? it's a skill set.
@twstnshout , I am a 4sp. kinda guy. Do what you need to do and put a T-10 in it and be happy.
Yes, a minor driveshaft change will be necessary but if you can't do it, it will be the cheapest part of the conversion. Modifying a drive line is really easy.
Go 4 and say no more!
Just an FYI there's a 55 with a 4 speed for sale on BAT right now, the owner might be able to give you some insight on what it takes to swap it out.
I would put in a new Tremec 5 speed, Mustang ‘93 or earlier style. Adapter, reasonably priced, available at John Mummert’s y-block site. Driveshaft would need to be shortened but that’s about it.
