1956 missing VIN plate
Rick Dawsey
Rick Dawsey
Jul 4, 2023
My friend's new (to him) 1956 Bird has no VIN plates, but he has the original buyers order (attached) and a 25 year old title. Can someone help us find the production code and trim code so he can have a new plate made?
Thanks in advance for your help!
Rick
1955
  • Resized_20240306_142944.pdf
I think you have everything you need. Let's see...
So, working from the invoice:
Serial No. P6FH 230518
Body 40A (we know this, since it's a Thunderbird)
Color A
Trim not shown on the invoice, but probably Black and White, or XA
Production Code probably 27BBX201
(27th day of Feb, BX dealer code [New York], 201st automobile for the day; the whole string is in the field "Item Number" on the invoice).
And there you have it
26FH 230518
40A A XA 27BBX201
Any idea why the plate is missing? Are the rivets or holes still there on the firewall? Does the sn match engine or frame?
Using your title, you can have a duplicate VIN tag made for the vehicle
I had a duplicate tag made by Marti here's their web site:
Rick
1955
Looking at my invoice my car was on the same assembly line that date and year
Rick
1955
I’ll admit to being the suspicious type when presented with a situation like this, but the first thing I’d do is verify the VIN stamped on the frame rail under the heater plenum matches the title. It wouldn’t be the first time a stolen collector car was sold under bogus paperwork. I hope I’m wrong but it pays to be careful.
No idea why it is missing. My best guess is that some painter in a previous day took them off and never put them back. The car's history and retention of old paperwork persuades me it is not a stolen car, which is always a concern.
Without the vin plate you have no history of the car.
The paperwork could be for some rusted out hulk laying behind a barn.
No idea why it is missing. My best guess is some painter in a previous day took them off and never put them back. The car's history and retention of old paperwork persuades me it is not a stolen car, which is always a concern.
Yeah like Rick mentioned check the vin on the frame rail.
Can you access that location without removing the body? If so, can you point me to how to locate it?
Thanks, Rick
The serial number that matches the number on the patent plate is stamped on the frame in three places, only one of which is easily available to view. The easily viewed one is on top of the frame on the passenger side underneath the heater box. It is about opposite the middle of the engine. It is not normally stamped that deeply into the metal and you may have to use some paint remover to see it.
Thanks, Rick
Here are the serial number locations on the frame. The body has to be removed to view the serial number on the top of the rear cross member and the one on the top of the X frame. The serial number on the top of the right frame side member is visible with the hood open.
As this thread shows, even *with* a data plate, you can't guarantee the history, as data plates can simply be replaced at will. The stamped numbers on the frame, however, would be much more difficult to change/forge.
I went to look for this on mine, and found it *baaaaarely* visible and only with the right angle of lighting, but it's there! Probably so hard to see because of the painting during the full frame-off restoration.
